Company Logo Shop Now
Green Diamond
Pantex12
10-23-2017 16:56:52
I pulled a green diamond flathead 6 out of my shop yesterday; the engine had been in there for 60 years. My dad had apparently made a stationary engine out of a McCormick Deering tractor. The engine is mounted on a frame with a MD hood and radiator shell. The engine is free and turns. I'd like to sell it but have no idea as to its worth. Can anyone give me some info as to what I might sell it for? Thanks
Pantex12
11-19-2017 06:47:29
 Re: Green Diamond in reply to Pantex12, 10-23-2017 16:56:52
. Yes. That is the engine. Thanks for that picture. If you know anyone who might be interested in the engine, please reply.
AlinMO
11-07-2017 12:05:46
Beautiful picture if Model 122 pulled by an M.
Is that your engine sitting on front top?
third party image
DESCRIPTION
View across field of a man harvesting wheat with a Farmall M tractor and No. 122 combine (harvester-thresher).
RECORD DETAILS
Image ID: 23922
Creation Date: 1948
Creator Name: International Harvester Company
City:
County:
State:
Collection Name: McCormick - International Harvester
Genre: Photograph
Original Format Type: transparency, color
Original Format Number: M96-253, Box 74, Fol. 4
Original Dimensions: 5 x 4 inchesthird party image
Pantex12
11-07-2017 10:32:35
I have discovered that the engine came from a McCormick Deering Harvester Thresher Model 122
Pantex12
10-24-2017 09:22:46
Panhandle, TX
jdv
10-24-2017 11:25:00
 Re: Green Diamond in reply to Pantex12, 10-24-2017 09:22:46
Give me a call575-447-4010 I’m in Clayton NM
jdv
10-24-2017 09:10:07
Where are you located? I have an old Ih truck that has the green Diamond in it, but it is unfortunately stuck. I may be interested in the engine.
Pantex12
10-24-2017 05:52:09
Could it have come from a pull type combine? The data plate says it is a model 122, serial #762.
leroy in ne
10-24-2017 07:30:31
 Re: Green Diamond in reply to Pantex12, 10-24-2017 05:52:09
possible in combine. Does it have a governor or is throttle rod hooked direct to carb.? truck application probably would be ungoverned. found info that green diamond was built 1934-1949 , 3 sizes 175, 214, 233 cubic inches were listed as green diamond.
leroy in ne
10-24-2017 04:38:25
I have seen this engine in a mid to late 40's truck. I believe a KB-5. estimate 1- 1/2 ton truck. I'm not aware of any tractor applications but may have been offered as an Industrial.
rustred
10-23-2017 17:32:31
as is... 2-300.00
Today's Featured Article - The Collection of a Lifetime - by Sherry Schaefer. The larest gathering of orphan tractors ever assembled by one collector will be auctioned off on May 15 in Rock Island, IL. Ed Spiess was a well known tractor buff who spent most of his time dreaming of rare and unknown tractors. His background as an agricultural engineer sparked his interest in the unique attributes of the models built from 1939-1959. ... [Read Article]
Latest Ad: Need a clutch shaft for a 46 Massey Harris 101 Jr., F162 Continental engine. About 18.25 inches long, to fit 1-1/8x 10 spline clutch disk. Bare shaft without sprocket or bearing is OK. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
