Company Logo Shop Now
Hitachi 14231 Dimensions
MNGB
10-06-2017 11:18:23
Hi all, can anyone give me the dimensions fo the Hitachi 14231 alternator, I stopped at the local O Reilly's auto parts but they didn't one in stock, what I'm wanting to know is the diameter and length thanks
GB in MN
MNGB
10-07-2017 19:33:40
 Re: Hitachi 14231 Dimensions in reply to MNGB, 10-06-2017 11:18:23
Hi Charlie got the message will call thanks
GB in MN
charlieu
10-07-2017 18:19:21
MNGB, If you are looking for a smaller Mini alternator, I have a 45 amp Denso. that is 5 1/2 inches long, about 4 inches in Diameter. The bolt holes are about 6 inch apart. Give me a call for more information. five zero seven- 438-8172 CharlieU third party image third party image
MNGB
10-06-2017 15:50:06
Thanks very much guys that's the numbers I wanted, I am refurbishing a John Deere LA and didn't get a generator with it so am looking at alternatives I have a nice Motorola alternator and its smaller than the Delco and it will fit under the hood but its really tight so will check to see if the Hitachi is smaller or the same.
Thanks again
rvirgil_KS
10-06-2017 11:40:42
third party image
Here are measurements of one I installed
Janicholson
10-06-2017 11:22:41
2/3s the diameter, and adjuster ear to pivot is close to 2 inches smaller than a Delco 10SI Metric ear hole and pivot holes can be drilled to fit US bolts. Jim
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
Latest Ad: JENSEN miniature pump jack. 13W. Operating smoothly. 5 weights. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
