S C valve seals
47fivewindow
09-21-2017 11:34:36
Our Super C Farmall smokes at idle and when going down hills. I would like to try umbrella seals on the valves. The ones I have found will not fit inside the springs. Does anyone have a part number? Thanks.
RedRamGT
09-22-2017 19:34:10
 Re: S C valve seals in reply to 47fivewindow, 09-21-2017 11:34:36
If the engine smokes going down hills, you could have worn piston rings. You might try a compression check, to see if that could be what's happening.
pete 23
09-21-2017 18:19:07
I put a lot of valve seals on C tractors over the years, but, did it with head off because the guide needed to be machined for a Perfect Circle seal to fit. We had a little cabinet IH sold with seals and tool. There are other seals that will work BUT, they need the guide machined to work the way intended. An umbrella seal is pretty much worthless unless the valve stem has a groove for it which a C does not. Also, guide have to be in good shape or no seal will last or do a good job. Last seals I bought, after I retired, were from CaseIH dealer but any machine shop can get good seals. I don't have a part number.
