Pto lever on my 1950 farmall h has a lot of play in it and it doesn't engage very securely. After running the brush hog for a few minutes it disengages. If I hold the lever down with my foot all is fine. This is my first tractor so not extremely knowledgeable. What could be worn? Is it the bearing or shift mechanism inside? Any help is appreciated.
Re: Loose pto lever and pops out/disengages. in reply to Cecil09, 09-04-2017 07:02:07
Depends on the engine serial number break. Search case ih parts diagram, like click here is #10 in diagram. On my 200 I made a poppet out of same diameter round stock. Grind the end like a bullet.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
