Farmall & IHC Tractors Discussion Forum |
Governor start-up question
Author |
[Modern View] |
Bigtone
08-27-2017 11:33:19
Super a started up earlier then died like it ran out of fuel. I pulled the carb went through it again, put it back on, and nothing. Turns over but won't fire. I checked the govenor rod and it was almost unresponsive with the throttle. I removed the gov to carb rod and the linkage from the gov had almost zero resistance like there was no spring, very sloppy. I'm guessing the spring is either broke or so worn it's affecting the ability too start. Does that sound right? Looks like a pain I the rear to remove cover, is it simple to get to once cover is off?
Bigtone
08-27-2017 14:24:41
Re: Governor start-up question in reply to Bigtone, 08-27-2017 11:33:19
It's a carb problem fellas, I have spark, I got it you start after playing with the idle screw but still screwed up, thanks for the input
old
08-27-2017 11:53:54
So if you set the throttle wide open does the carb linkage move to wide open?? If it does ok and then if you move the throttle to idle does it also move the carb linkage to idle?? If it does then you don't have a problem and not likely to be your no start problem
Bigtone
08-27-2017 12:59:14
Re: Governor start-up question in reply to old, 08-27-2017 11:53:54
When I open the throttle it will open the carb but when I try to bring it back to idle the carb rod doesn't move, I have to manually move the rod. I have the bend of the rod going to the carb against the block, could I have the rod the wrong way and restricting movement? But that doesn't explain how it ran fine then all of a sudden died... unless that spurring let loose a little more... any ideas
Bigtone
08-27-2017 12:20:40
Sometimes the rod moved a little and then it didn't move at all, I had to play with the throttle back and forth for it to move
Used red mn
08-27-2017 13:48:00
Re: Governor start-up question in reply to Bigtone, 08-27-2017 12:20:40
Did you check for spark? Is it a battery ignition? If so is it getting power? Is the distributor turning?
Bigtone
08-27-2017 13:51:00
Re: Governor start-up question in reply to Used red mn, 08-27-2017 13:48:00
It's a magneto and I'm going to go check for spark after dinner
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important
... [Read Article]
Latest Ad:
1967 Ford 3000
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
