6 V Generator....1944 Farmall H
banjoman09
08-24-2017 08:18:07
Anyone have a GOOD "6 V Generator" they would sell me....news ones are pricy.....thanks.
gene bender
08-25-2017 06:47:45
 Re: 6 V Generator....1944 Farmall H in reply to banjoman09, 08-24-2017 08:18:07
When you ground the field does that make it charge. If it doesent charge with field grounded the gen is bad. If it does charge with field grounded the reg is bad. That system used a cut-out and if it has been changed to a regulator mite be the wrong one. Is the Delco # on the gen end with 355 or 423. as those were the #s of the original gens.
banjoman09
08-25-2017 09:29:11
 Re: 6 V Generator....1944 Farmall H in reply to gene bender, 08-25-2017 06:47:45
Yes it did charge when the Field is grounded- but no juice on Arm post- it is in the shop now so should be ok when I get it back....Thanks!
ljw
08-24-2017 18:15:21
call or text for shipping details. six 1 two 86eight zero zero six 8
ljw
08-24-2017 16:35:36
I have a good one from a 46H. Pay the freight and give me a few $$ and I will send it to you. I'm in MN. Or I can send it to you before you pay.
banjoman09
08-24-2017 18:01:46
 Re: 6 V Generator....1944 Farmall H in reply to ljw, 08-24-2017 16:35:36
6 v ..... deal....
banjoman09
08-24-2017 16:29:16
I have taken this generator to a shop that does these; I rewired my tractor with "10 gauge" wire.... Hope to have it fixed and working soon. I know everyone is tired of seeing this post - including me! Thanks.
RC Brooks
08-24-2017 10:52:48
And $200 is very, very high for a generator rebuild. If it were some foreign generator that they only made 50 of... sure. Generators are pretty simple and the ones on these tractors are pretty common. You may call around at your local small engine shops too.
dhermesc
08-24-2017 17:27:23
 Re: 6 V Generator....1944 Farmall H in reply to RC Brooks, 08-24-2017 10:52:48
I was having a starter worked on - same shop does both and I'm sure he did them both just as poorly.
erskine2017
08-24-2017 10:33:22
Have you thought about a Hitachi Alternator and converting to 12 volts. The Hitachi is small and will fit your H tractor without mutilating the hood. Like a Delco, the regulator is self contained.
banjoman09
08-24-2017 16:26:15
 Re: 6 V Generator....1944 Farmall H in reply to erskine2017, 08-24-2017 10:33:22
Nope- I keep everything "original". Thanks
Janicholson
08-24-2017 09:19:30
That generator is not bad. (opinion) take it to a generator shop and have it tested before spending massively on it. We cannot be next to you as the tests are performed. If there asr issues with it having it rebuilt is far better than a new one as the new are likely imported similar items. Jim
dhermesc
08-24-2017 09:43:11
 Re: 6 V Generator....1944 Farmall H in reply to Janicholson, 08-24-2017 09:19:30
You have to make sure its a good shop. I brought a 50 year old starter with a dead spot to a local shop that had been around forever and supposedly had a "good" reputation. After spending $200 to have them rebuild it I got about a week of use out of it and another week of utter frustration before it burned itself out. The "cheap import" I bought to replace it seems to be just fine.
erskine2017
08-24-2017 10:48:47
 Re: 6 V Generator....1944 Farmall H in reply to dhermesc, 08-24-2017 09:43:11
Starter Armatures are difficult to diagnose even with a growler as the armature wiring of a starter is so much larger than that of a generator.
banjoman09
08-24-2017 16:27:09
 Re: 6 V Generator....1944 Farmall H in reply to erskine2017, 08-24-2017 10:48:47
this is a generator.
banjoman09
08-24-2017 10:00:36
Yeah - know the feeling; but here I go; found a shop that has been in business along time- 50 miles from me but im loaded up and heading over...thanks... I would think if you spent that much they should have "stood by it" for you; wish me luck. Thanks!
banjoman09
08-24-2017 09:35:21
ok.....thanks
