I have a 1946 Farmall H and I recently rebuilt the carb-mainly for cosmetic reasons. When I started the engine for the first time since rebuild, it started right up how it leaked a fairly large amount from the drip (weep) hole on the bottom. I did have the choke on so I turned it off and the same thing happened however much less.
I have read various old posts where people had similar problems that were float related. I was able to confirm free movement of the float after rebuild and before installation however I don't know how to once its installed other than removing it again.
I didn't have any problems with the rebuild except the the main adjustment screw gasket is very tight which makes the screw very difficult to turn. Due to this I am not able to feel when the adjustment screw touches the seat so I can't accurately tell how far out the adjust meant screw is. It's clearly not too far in cause it runs ok. It may be too far out, would that cause a leak through the drip hole?
