Where's the H dip stick
Clay Robinson
03-05-2001 10:50:11
I just bought an H (don't even know the year model yet). I can't find a dip stick! Is there a fill level hole? Also, how do I check the differential level? 90EP ok? I will eventually get a manual but I drove it 16 miles to get it home and I want to know the oil levels are good.
RickB.
03-05-2001 11:48:30
 Re: Where's the H dip stick in reply to Clay Robinson, 03-05-2001 10:50:11
Your engine oil level must be OK or you would have grenaded it long before you made it 16 miles.
The Red
03-05-2001 10:55:39
Congratulations Clay. You will enjoy the old H. Look at the oil pan on the distributor side. You will see two petcocks. Maintain your oil level between those two petcocks. The H engine takes 6 quarts.
On the transmission in front of the clutch pedal shaft is a check plug. Unscrew that plug. If 90W flows out, the transmission is full. If not, the big ol cap next to the steering wheel post is where you add 90W. Use a 3/4 socket drive to loosen up that cap. Transmission holds 6 GALLONS of 90W.
The air cleaner cup takes about 1 quart of SAE 30. That is an easy one to forget and they can get quite gunky.
My H has a Dipstick!
03-05-2001 11:09:14
 Re: Re: Where's the H dip stick in reply to The Red, 03-05-2001 10:55:39
The dipstick on my H sits behind the steering wheel.
Andy Martin
The Red. ROFL!
03-05-2001 11:14:43
 Re: Re: Re: Where's the H dip stick in reply to My H has a Dipstick!, 03-05-2001 11:09:14
Actually Andy you got two. You forgot the liftall dipstick. :)
Andy Martin
03-05-2001 17:21:10
 Re: Re: Re: Re: Where's the H dip stick in reply to The Red. ROFL!, 03-05-2001 11:14:43
I am dipstick challenged. Out of 13 tractors with lift-alls, I only have two with dipsticks (and neither is an H).
I am planning on making some, when the cotton's high and the corn's a growing...
dick
03-05-2001 11:25:47
Hey Red - What's ROFL translate to???
The Red
03-05-2001 11:50:34
 Re: Re: Re: Re: Re: Where's the H dip stick in reply to dick, 03-05-2001 11:25:47
Rolling on floor laughing. :)
