44farmallH
New User
I have a 1944 Farmall H that was restored about 5 years ago, but now am having difficulty starting it. I decided to convert it to 12 volt. It was positive ground, so I put in a new 12 volt battery, ran a cable from the negative post to the ground at the starter. Ran a cable from the positive post to the starter button, where there I also connected a wire to the new 60 amp ammeter. The other wire from the starter post went to the starter. Where the wire from the starter post connected at the ammeter, I also connected the wire for the new ignition switch, as well as a wire connected to a 20 amp fuse that ran to a new 4 position light switch. The other post on the ammeter just has a wire running to the new alternator. From the other connection on the ignition switch, I have a wire running to the positive side of a new 12 volt coil with internal resistor. A wire from the negative post of the new coil runs to the distributor. Replaced the distributor cap and ran all new spark plug wires and put in new spark plugs. When I turned on the ignition switch, my test light shows power to the starter post and also at the new ignition switch, the alternator and the coil. When I try to crank, I can see spark at the points where the distributor cap and rotor come off. I do have a spark plug analyzer that shows that there is a spark (although very small and hardly noticeable) to the plugs from the distributor to the plugs. Tractor still won't start. I took off the carburetor and everything seems fine.
The other issue I'm running into is the rear taillight will not work. I installed new wiring to the headlights and those work fine. I have a wire running from the ammeter to the 4 position light switch with a fuse, and then a wire running from the light switch to the headlights. Again, they work fine. I then have a wire that runs from the light switch to the rear light. My test light shows that this connection is good. I also tested where the wire attaches to the back side of the tail light fixture - test light comes on. I took the old housing inside apart and the test light comes on where the inside housing attaches to the post inside. But the unit itself still wouldn't light. I ended up buying a new housing....same problem. Test light comes on outside the unit, inside the unit and also where the light bulb makes the connection to the housing wire itself....I tried several bulbs.
Any ideas?
Any ideas?
