anotherbri
I got my 2 loader cylinders off and apart. Trying to replace the seals at the end because oil was spitting out. It had 4 rubber seals stacked on top of each other. I believe these seals are called chevrons or v-packing. These seals were compressed between 2 brass bushings. I picked up new seals at my local Hydraulic shop but the new ones are made of leather. These leather seals are so stiff that when I install them and compress them between the bushings, they flatten out and the inside diameter becomes so small I don't think there will be any way to slide the shaft through them without ruining them. Has anyone ever replaced these seals? And if so, did you use rubber or leather?? And were there 4 in your unit?
I really need to get this back together.
Thanks
Harry
Thanks
Harry
