Company Logo Shop Now
adding a control valve to IH 684
gleanerguy
07-10-2017 08:38:40
I have a 684 that I use for raking. I want to add a set of outlets, as now I have a wheel rake that requires two sets of outlets. Can I just buy another control valve and bolt it on to the existing valve? I already have a power beyond setup for my loader. I would rather run the other set out of the back rather than running a pair of extended hoses up to the auxillary valve.
Has anyone tried adding another valve?
caterpillar guy
07-11-2017 02:31:15
 Re: adding a control valve to IH 684 in reply to gleanerguy, 07-10-2017 08:38:40
Some of those tractors had 2 different valves so you would have to get the correct valve for the tractor. A junkyard should have all the parts including the steel lines for what you want to do. There are 2 slots in the sheet iron for 2 levers down by your right foot.
IHTimmy
07-10-2017 10:11:40
I have used a electric control block with the switch at the back and all you have to do is flip the lever one way to use one side or the other way to use the other side you would plum right into your remote at you would use your regular handle to use it on the rake I've done his years ago and he still uses it
IHTimmy
07-10-2017 14:30:55
 Re: adding a control valve to IH 684 in reply to IHTimmy, 07-10-2017 10:11:40
Summit hydraulics part number HM2 -08 – SBC it has everything you want but two hydraulic lines
gleanerguy
07-10-2017 13:53:55
Where do you get this electric control block?
MikeinKy
07-10-2017 19:49:52
 Re: adding a control valve to IH 684 in reply to gleanerguy, 07-10-2017 13:53:55
The electric control is sold by Shoup or Sloan Express. I have one for a hay rake on my 2510 JD, and it works really good. It is easier and a little cheaper than adding a valve. When you don't need it, it can be removed in 5 min. Two wires to the battery and the switch has a magnet on it.
Today's Featured Article - 1935 John Deere BN History - The History of My Tractor - by Alexander G. Knox. My grandfather, Orval A. Knox of Chandler, Arizona, affectionately known as Pa, purchased this tractor new from the John Deere/Caterpillar dealer (now Arizona Machinery) in 1935. It was his first new tractor and his first with rubber tires. He used it on his farm growing cotton, alfalfa, corn, wheat, milo, barley, and oats. My father, Norman L. Knox, recalls Pa putting a mower on the tractor during the day and then ... [Read Article]
Latest Ad: 11-2-34 tires [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
