My original problem on this 300U is that the loader and bucket leak down and there doesn't seem to be a good fix The loader is currently plumbed though the original hydro touch valves but spending $1,200 or more on two new valves that are difficult if not impossible to find doesn't seem like the right thing to do right now.
What I am considering is to cut a section out of the pump pressure hard line then braze on two hydraulic fittings. This would allow me to feed a new style joystick or two spool valve for the loader with that pressure and then feed the return right back into the pressure line.
I actually can see a couple problems with doing this. (1) Would it work and still allow the rest of the system to function? or (2) Would it completely divert all pressure away from the power steering while the loader is in actual use? (3) If it diverts all pressure then how to combat that problem?
Obviously I would not want to cut an original hard line if this would not work anyway. However keeping the tractor "original" is not a big concern for me. I just need the loader to work properly.
Any help would be much appreciated.
[/img]
[/img]
