farmall 300 throttle adjustment.
dewy
07-03-2017 13:07:46
whats the best way to adjust throttle with gov linkage.....thanks as always,,,and happy 4th,,,,, dewy
old
07-03-2017 13:44:06
 Re: farmall 300 throttle adjustment. in reply to dewy, 07-03-2017 13:07:46
The I-T manual has close to a page a n half that explains how to do it so it would be hard for us to post what all you have to do to do it correctly
dewy
07-03-2017 14:56:45
 Re: farmall 300 throttle adjustment. in reply to old, 07-03-2017 13:44:06
thanks.old i have the book....i will do it...i had changed the throttle lever washer an broke bolt..drilled out an put back together and trottle response was different...idles all the way to 3/4 open then i get hi rpms....all i did was unhooked it in front of gas tank...it was just a cotter pin ...i didnt adjust anything.....thats why i asked cause it wasnt like that before...so ididnt know if i should get in the gov or not..... thanks..dewy
