Painting
ksk
03-03-2001 10:43:06
what kind of paint should i paint my farmall c tractor for long term looks
tommyw
03-03-2001 18:08:01
 Re: painting in reply to ksk, 03-03-2001 10:43:06
the sky is the limit!, the best is imron, or delta very expensive very hard to spray and toxic, (supplied air resperator required) another good choice is ppg delstar about 200.00 a gallon + catalist and reducer, holds color several years outside in texas sun. as for cheaper paint ppg makes a line of industrial paints, they are pretty durable and cost 40-70$ a gallon, they hold up good in the sun and wont break the bank....thats what i would use, they are called ppg LIC industrial coatings, you will get lots of options on the forum, im a professional paint and body man , and part time farmer . e -mail me and ill give you info . if you need help. WEAR A GOOD MASK WHEN PAINTING PAINTS TODAY ARE MORE DURABLE AND MORE TOXIC!
abane
03-03-2001 15:45:25
John Deere red is the best looking and holds a gloss years after other paints--about $40 a gallon.
jiM
03-03-2001 14:31:59
I had good results from the DuPont brand that matches IH red.
Phil Auten (TX)
03-03-2001 13:19:05
Get I-H 2150 from a Case/IH dealer and the hardner that goes with it. It will last for years if the tractor is stored inside. The hardner requires that a good respirator be worn when painting!
Phil
ksk
03-03-2001 12:00:31
cost is a facter but there all type paint one can get I paint some equitment with some paint I got form tractor supple that faded in couple month I spent a lot time painting just faded i dont want that to happed again I am willing spent couple hunderd so I dont have too do it again in couple months
sammy the RED
03-03-2001 11:35:50
How much $$$ do you have to spend ?
