F12 rod caps
Farmallboy
03-02-2001 17:18:10
What should the bolts be torqued to.I have them at 40 foot pounds now and I am about to put the pan back on.I looked in the shop manuals and they only told me clearances not torque specs.Please help me.Thanks
MikeH-Tx
03-03-2001 07:00:45
 Re: F12 rod caps in reply to Farmallboy, 03-02-2001 17:18:10
That's about right. With the cotter pins through them, you don't need to worry about tightness for the sake of staying secure, only for tension on the bearings.
I tightened them with a normal socket wrench, then measured one with a torque wrench. It was 50lbs. Then, I tightened a little more until the cotter pin hole lined up. Probably resulted in 60lbs or so, but I didn't measure.
Farmallboy
03-03-2001 13:22:06
 Re: Re: F12 rod caps in reply to MikeH-Tx, 03-03-2001 07:00:45
Thanks,should get the cotter pins in it and put the head back on and hope she runs.
