Company Logo Shop Now
farmall 300 row crop ipto
dewy
06-07-2017 19:07:14
was runnin brush hog in some red ceder limbs i cut down on fence line , big as your wrist and alot of them...it never looked back...eat them up.......got in some tall grass and to close to garden where some dirt was from garden and the pto acted like it was slippin,, lost pto speed but caught back up..only did it once in grass....what yall thinks goin on......thanks again in advance......dewy
Janicholson
06-07-2017 20:10:35
 Re: farmall 300 row crop ipto in reply to dewy, 06-07-2017 19:07:14
The linkage on well used PTOs on the 300 and 350 series become dysfunctional after years of use.
Two suggestions:
Make very sure there is no lost motion in the hand lever pivot and rod mechanism. Be certain the hand lever moves the PTO lever from the middle both ways with zero lost motion.
Adjust it like this, after there is no play in links.
Move the lever exactly half way between the locked on position and locked off position (little flipper catch on lever. use a bungy or wire to hold it there.
Take off the little dome metal cover from the adjust screws.
Loosen the jamb nut, and tighten the front (away from you) screw until it is just a bit tighter than the point at which it begins to feel tighter as it is screwed in (maybe a eighth turn) then back it off until the PTO shaft will turn with least drag (about 3/4 turn out) and tighten the lock nut while holding the adjuster.
Do the same for the closer adjuster.
If the screws go into the jamb nuts and get flush with the top surface of the nut, the bands are probably worn out, and may be operational for a while, but plan on a rebuild.
Now (tractor off) push the the lever down toward the brake footplate. As it goes down, it should get harder to push when it is about 4" (or so) away from fully OFF. and be noticeably harder to push for the last inch, but not real hard. (this is the brake band tightening on the drum in the PTO unit.
Then pull it up and do the same feel.
The ON position should feel the same way.
The shaft should turn pretty free when the lever is half way, and not at all when in either ON, or OFF. (tractor shut off)
If it slips now, it needs a rebuild. JimN
dewy
06-07-2017 21:06:34
 Re: farmall 300 row crop ipto in reply to Janicholson, 06-07-2017 20:10:35
thanks jim i will try it........if have to rebuild ..how hard is it......and whats involved in it .thanks dewy
Janicholson
06-08-2017 10:41:05
 Re: farmall 300 row crop ipto in reply to dewy, 06-07-2017 21:06:34
Not radical, but you need a repair manual. Take photos every 3 minutes. It is not as tough as an automatic trans, but has similar parts. Jim
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: Excellent original John Deere 60, #6000612, original paint, rear tires, seat cushions, can email pics. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
