work around from side dresser
riverbend
I would like to side dress vegetables when cultivating with a Super C. It has been a long time since anyone around here has seen side dressers that weren't completely rusted out.
Is there something that I can substitute that will do the same job ? Has anyone done a DIY version ?
Thanks
Greg
I have a good John Blue brand one row sidedresser outfit that came off a Super C you can get cheap if you are close enough to pick up. Email me for more info if you are interested.
I built my own. Everything that touches fertilizer is stainless. Cultivator frame is on other side of tractor. Got about $40 in it.
Richard in NW SC
Just mount a tank and use liquid run hose down to the shovel using a ball valve to open and close the flow. I did that for sweetcorn on an A worked well. Would be easy to do.There are different ferts that are water mixed to use. Just visit your garden center to find the one you want to use.
Thanks. A very good friend gave me the clutch mechanism sitting on the axle. I fabricated most everything else from stuff here on the place. Had to buy the stainless steel bolts.
Richard
