Company Logo Shop Now
What is this.
dgoodman2
05-13-2017 20:02:24
third party image
third party image
Hey guys. Was looking at this tractor for some parts. The owner calling it Super M and so does sticker. But I don't see hydraulics under gas tank.
Is this M or Super M?
kcm.MN
05-16-2017 07:36:58
 Re: What is this. in reply to dgoodman2, 05-13-2017 20:02:24
Yeah, them JD guys'll never know the difference. :lol:
Just teasing guys - but this "is" the Farmall section ya' know! :P
braol
05-16-2017 07:08:51
Well, I may be a brand-new Farmall owner but as an experienced mechanic it almost looks like the tractor is sporting old replacement tin with new decals. In the end, I guess as long as it runs and you enjoy the machine it is a win for everybody!
rustred
05-14-2017 08:25:01
the serial # will tell you.
henryv11
05-14-2017 07:30:00
Wouldn't the serial number tell you something or isn't the tag there.
D beatty
05-14-2017 07:23:55
It looks like somebodys cobble job.
F-Dean
05-14-2017 07:08:02
Could it be a M that had the engine rebuilt with Super M sleeves & Pistons? Thus, some may consider it a "Super Powered" M.
rustyfarmall
05-14-2017 06:54:32
BINGO!!!
Donald in mn
05-14-2017 04:50:46
looks to be what the ford N series guys call a franken tractor one made up from parts of different model year tractors.
dgoodman2
05-14-2017 18:24:17
 Re: What is this. in reply to Donald in mn, 05-14-2017 04:50:46
Donald. That has become my conclusion also. Seems right on target. I believe I'll just leave it alone.
Thanks.
dgoodman2
05-14-2017 04:14:16
I did notice the brakes and was thinking that was a regular M. It has some plumbing in the belly so I was thinking pump at distributor was added later. All indications of a M.
Just curious. He says it's a Super because it has 3 bolt starter. Is there a 2 or 3 bolt.
Thanks.
D Slater
05-14-2017 04:53:38
 Re: What is this. in reply to dgoodman2, 05-14-2017 04:14:16
Yes 3 bolt starter after a serial break, that's why I said stage 2 center housing. Also has extra bosses on center housing above left hydraulic outlet holes. When drilled and threaded were used for battery box mounting on a SW-6 with frame rails. Doesn't have the starter setup for a stage 2 SM. It had a pull rod operation from the bracket bolted to rear fuel tank support. Bracket is only used on stage 2 SM that came without a engine driven liftall system and was also used for choke rod and belt pulley gear box operating rod if equipped. Stage 2 amp gauge box should have the ignition switch in cover.
D Slater
05-14-2017 03:19:40
Looks like both, need to look closer to see what's what. Looks like a stage 2 SM center housing, stage 2 SM frame rails and can't be sure but looks like the bigger diameter upper pipe end to air cleaner. Think if the pipe came on a M it would be late enough to have disc brakes. Front wheel pictured is for a real late M, SM through 450. Carburetor choke lever is on a M side. M&W hydraulic pump on the tractor. Battery box and shift lever is added or a M rear end put under the parts. Would check to see if engine is a SM. If so maybe mostly a M rear put on a SM chassis with a few other things.
Rex Simpkins
05-14-2017 03:43:57
 Re: What is this. in reply to D Slater, 05-14-2017 03:19:40
It looks just like mine, a Stage 2 Super M that was ordered with a belly pump--then some time later someone wanted live hydraulics so they put a live pump on it and used the belly pump area for reservoir.
Rex Simpkins
05-14-2017 03:47:53
 Re: What is this. in reply to Rex Simpkins, 05-14-2017 03:43:57
OOPS, missed the brakes well its not a Stage 2. except for that it is set up like mine, Louisville serial L509XXX
Bob M
05-13-2017 21:05:59
Band brakes make it a regular M.
Live pump is aftermarket - Behlen perhaps?
Lmack
05-13-2017 20:53:05
It has hydraulics. Look at the distributor.
Gary Mitchell
05-14-2017 09:04:40
 Re: What is this. in reply to Lmack, 05-13-2017 20:53:05
It also has the battery box seat of a super. gm
Today's Featured Article - Allis Chalmers ED40 - by Anthony West. Allis Chalmers as a tractor manufacturer in its own riht is but a memory. However the number of AC tractors still in existence today as either restored or unrestored examples is a testament to the quality of their products. This in itself is always apparent here in the U.K when attempting a purchase, as no matter what the model or condition the price will always be strong. ... [Read Article]
Latest Ad: Scraper 16 yard carry type. Southwest welding manufacturer company, Alhambra California Made around 1938. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
