Farmall H hyd-coupler shaft.........
banjoman09
04-26-2017 14:00:39
Ok...I wasn't sure what to call this! Lol....Bear with me! Last week I posted about my transmission seal retainer- I have that fixed. The shaft right under it...coupler shaft- I removed it and need to replace seals....I have seals...but cant figure out how the slotted ends come off the shaft- to remove seal. Or do they?
David G
04-26-2017 16:12:18
 Re: Farmall H hyd-coupler shaft......... in reply to banjoman09, 04-26-2017 14:00:39
Zach's got it
Zachary Hoyt
04-26-2017 15:18:36
Put the tractor in 5th, lock the brakes, block the rear wheels. Find a long bar or a piece of 1/2" steel or anything that will fit and give you leverage. It unscrews normally, right hand threads. It may take a lot of force to get it started but then it will usually spin right off.
Zach
banjoman09
04-26-2017 16:49:04
 Re: Farmall H hyd-coupler shaft......... in reply to Zachary Hoyt, 04-26-2017 15:18:36
awesome....thanks!
banjoman09
04-26-2017 19:10:54
 Re: Farmall H hyd-coupler shaft......... in reply to banjoman09, 04-26-2017 16:49:04
I had a tie-rod adjusting tool , 3/4 drive, in my tool box. Used it and it worked great ! Thanks
