200 sterring
Oregonfarmer
04-19-2017 08:34:07
I have a very nice Farmall 200 wide front with 6.00x16 3 rib fronts. I drained the gear box and added STP with some gear oil to it. It still turns hard in either direction. Our M and H steer much easier. Any ideas or is this the nature of the beast? Thanks
gene bender
04-19-2017 10:57:50
 Re: 200 sterring in reply to Oregonfarmer, 04-19-2017 08:34:07
Jack the front of the tractor up so both wheels are free grease the spindles till they turn free and easy with the wt off them the grease can also go down. You mite need to take the link off at the top so you can get the spindle loose and grease where its needed at the bottom where the flange is
BarnyardEngineering
04-19-2017 10:16:45
The Super C (earlier version of a 200) drives like a go-kart and steers very easy in my experience. You have some binding somewhere. Could be in the gearbox. Could be at one or both of the knees.
