Farmall & IHC Tractors Discussion Forum |
Farmall H drive Dog seal removal
Author |
[Modern View] |
Jawhiz1
04-13-2017 13:49:18
Can anyone tell me how the two shafts come out it would be the two that connect the bell pump to the back pretty sure you don't have to split this tractor to change them. Hopefully someone can shed some light on this for me
Jawhiz1
04-14-2017 13:37:10
Re: Farmall H drive Dog seal removal in reply to Jawhiz1, 04-13-2017 13:49:18
Thank you very much much appreciated
Jawhiz1
04-14-2017 08:54:43
Do they spin counterclockwise?]
John M
04-14-2017 13:17:11
Re: Farmall H drive Dog seal removal in reply to Jawhiz1, 04-14-2017 08:54:43
Jawhiz1
04-14-2017 01:57:49
Ok the shafts is held together with cotter pins in the center connecting the front to the back so taking the center piece out which is the simple part. Now I want to remove the shafts themselves so I can replace the seals where I can stop the leaks
John M
04-14-2017 03:24:02
Re: Farmall H drive Dog seal removal in reply to Jawhiz1, 04-14-2017 01:57:49
The drive dog should unscrew. It may be a pian to get off. Put the tractor in gear, lock the brakes. At this point, sone use a pipewrench, some make a socket to use with an impact. Nut comes off, remove 3 bolts, replace the seal. Top is pretty much the same, except no drive dog to spin off. Take it all apart, take seal housing off relace seal and reverse.
fbh44
04-14-2017 01:24:32
Not sure exactly what you're asking, but if you remove the 4 taper bolts / nuts / washers in the bent ring gizmo, on the end of that short drive shaft, everything will just come out or slide out. NOTE--- when you reassemble everything, the bent ring gizmo can be re-installed two ways; with the maximum amount of space inside, and with the minimum amount of space. [Pivot it around and you'll see.] BIG DIFFERENCE! Install it with the MAXIMUM around of space. Otherwise that short drive shaft will not be seated inside the pilot bearing. There, I've just saved you a learning curve and a hard expensive lesson to learn. It can all be done without splitting, just wear some safety glasses to keep the grit out of your eyes.
John M
04-13-2017 17:57:30
The belly pump drive shaft? Pull the cotter pins, slide the collars in and it should just about fall out.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
1935 John Deere BN History - The History of My Tractor - by Alexander G. Knox. My grandfather, Orval A. Knox of Chandler, Arizona, affectionately known as Pa, purchased this tractor new from the John Deere/Caterpillar dealer (now Arizona Machinery) in 1935. It was his first new tractor and his first with rubber tires. He used it on his farm growing cotton, alfalfa, corn, wheat, milo, barley, and oats. My father, Norman L. Knox, recalls Pa putting a mower on the tractor during the day and then
... [Read Article]
Latest Ad:
11-2-34 tires
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
