560 Wheatland power steering
toolz
03-25-2017 20:35:10
I took the power steering off of my 560W. Can the hydraulic lines be plugged off, or should I loop them together?
charlieu
03-26-2017 17:38:11
 Re: 560 Wheatland power steering in reply to toolz, 03-25-2017 20:35:10
560 had two (2) hydraulic pumps, they were piggybacked. You either have to run a loop hose or remove the pump and then you plug the ports. You will also have to install a cover on the back of the main hydraulic pump, otherwise the main pump can suck in unfiltered oil from the housing.
toolz
03-26-2017 18:43:38
 Re: 560 Wheatland power steering in reply to charlieu, 03-26-2017 17:38:11
Thanks for the help. Looks like I'll just go the easy route and keep the lines looped.
rustred
03-26-2017 17:51:03
so there is another pump in there just for the power steering?
rustred
03-26-2017 17:18:28
take the lines off from the pump housing and from the hydraulic pedestal and plug them the same as factory did. there is a blanking plate for the hydraulic pump side and a plug for the pedestal side. its all run off the same hyd. pump.
Dieseltech
03-25-2017 20:50:41
Best loop them together if the power steering pump is still in place. Capping the lines will blow the relief valve all the time, damaging the pump.
toolz
03-25-2017 21:24:19
 Re: 560 Wheatland power steering in reply to Dieseltech, 03-25-2017 20:50:41
That's the way I have it now. just wanted to clean things up a little. Never worked on a steering pump on one of these. Just always assumed the power steering ran off the main hydraulics. Learn something every day!
