Author |
[Modern View] |
FarmallLovinGuy
02-26-2017 17:25:53
Does anyone know what the stock cigarette lighter looks like on a Farmall 450. Does anybody have a picture of the lighter or know where to get one. I've seen some on the Internet, just not sure if they look like the originals. Thanks.
55a
02-27-2017 19:42:14
Re: Farmall 450 Cigarette Lighter in reply to FarmallLovinGuy, 02-26-2017 17:25:53
  O'rellys auto parts has them for about 7 to 8 dollars. You need to get the one with a shoulder.
jeffcat
02-27-2017 10:03:26
Just remember they call them "Power Ports" now. If you look into it there is no spring clip anymore. Won't even let a lighter work.
AJB-830
02-27-2017 07:33:36
  Here are a couple of pictures of the cigarette lighters on a couple of my 450 tractors. I believe the 1st one is an original. The 2nd picture is what I was able to purchase from my CaseIH dealer back in about 1996 when I re-did the dash on another 450-D. Hope this helps. Al
OldFarmall450
02-27-2017 01:02:41
My 450 still has the stock cigarette lighter, a little faded but works...ok, a LOT faded...pity i gave up smoking !
D beatty
02-26-2017 18:16:51
 Mine is like this one. It's the black knob to right. The only thing is mine says lighter on knob.
FarmallLovinGuy
02-26-2017 19:32:53
Re: Farmall 450 Cigarette Lighter in reply to D beatty, 02-26-2017 18:16:51
 Does it look like this one?
D beatty
02-26-2017 19:48:40
Re: Farmall 450 Cigarette Lighter in reply to FarmallLovinGuy, 02-26-2017 19:32:53
 That's the one they say is for a IH 450 but I didn't like it so I put this one on and it was the same price. A lot of guys don'i put the lighter in when restoring tractor they just plug it.
FarmallLovinGuy
02-27-2017 05:03:33
Re: Farmall 450 Cigarette Lighter in reply to D beatty, 02-26-2017 19:48:40
Thanks for your help. By the way, that is one fine tractor you've got.
Fritz Maurer
02-26-2017 18:58:27
That thing is beautiful. Post a side view of it , would you?
D beatty
02-26-2017 19:21:24
Re: Farmall 450 Cigarette Lighter in reply to Fritz Maurer, 02-26-2017 18:58:27
  That is a picture like mine since I don 't have a close up of mine. On mine all knobs and starter button are new. The picture below is actual picture of mine.
AJB-830
02-27-2017 07:39:31
Re: Farmall 450 Cigarette Lighter in reply to D beatty, 02-26-2017 19:21:24
Your 1st picture of the cigarette lighter looks like a restored 450-D with a wide front. Is that correct? I would like to see a picture of that one. I also have a couple of 450-Ds but mine aren't restored. Al
dblair
02-27-2017 06:29:51
of subject I know but how much does your tractor weigh ?
D beatty
02-27-2017 10:27:58
Re: Farmall 450 Cigarette Lighter in reply to dblair, 02-27-2017 06:29:51
  The picture of me pulling she weighs 8,000 lbs. with me on it. It has no fluid in tires but 2 wheel weights on each rear wheel and set on front wheels I carry a 1,000 lbs. of bar bell weighs that I can remove and drop down a class.
dblair
02-27-2017 14:12:27
Re: Farmall 450 Cigarette Lighter in reply to D beatty, 02-27-2017 10:27:58
I have a friend that has a 58 mine is a 57 but doesn't look as great as yours . my friends 450 with one set of weights weighs in at 5800 pounds mine with no weight weighs 6300 . with no weight what does yours weigh if you know with no weight ?
D beatty
02-28-2017 00:28:06
Re: Farmall 450 Cigarette Lighter in reply to dblair, 02-27-2017 14:12:27
If I would take all the weights off it would be 6,300 lbs. and that's with no fluid in tires.
dblair
02-28-2017 06:37:05
Re: Farmall 450 Cigarette Lighter in reply to D beatty, 02-28-2017 00:28:06
 here's mine ready to go pulling
D beatty
02-28-2017 07:45:34
Re: Farmall 450 Cigarette Lighter in reply to dblair, 02-28-2017 06:37:05
  Nice out fit. I have been looking for heavier truck to pull trailer so I can take both tractors to pulls or shows.
dblair
02-28-2017 08:44:36
Re: Farmall 450 Cigarette Lighter in reply to D beatty, 02-28-2017 07:45:34
that's a great looking wd45. I had to go to a bigger truck than the ram 3500 I had because it wouldn't stop the rig with a 6k trailer and a 9k tractor on board . this truck doesn't have the power of the ram but it will certainly stop .
D beatty
02-28-2017 11:03:24
Re: Farmall 450 Cigarette Lighter in reply to dblair, 02-28-2017 08:44:36
Braking is the reason I want to go bigger. I had a car last fall stop at stop sign and about the time came up on cross road he pulled out in front of me and I thought I was going to hit him but brakes did stop me but was a very uneasy feeling. I had the 450 weighing 8,000 lbs. trailer 4,200 lbs. and truck just a little over 5,000 lbs.. I kick myself several weeks ago for not calling sooner but found a 1988 Chevy 7,000 series tractor with 427 v8 with 5-2 and less than 80,000 miles and never used in winter and photos it look like new.
dblair
02-28-2017 12:45:31
Re: Farmall 450 Cigarette Lighter in reply to D beatty, 02-28-2017 11:03:24
that would be a great truck to have . sounds like a farm truck , lot of years little miles equals good value . plenty of power in a 427 .
steve_in_mo
02-26-2017 19:13:12
Really! We need a lot of pictures of that one.
