Farmall & IHC Tractors Discussion Forum |
350U power steering ??
Author |
[Modern View] |
Duner Wi
01-19-2017 10:01:07
What would/could cause the expansion plug to dislodge and let the steering box oil out. Plug is located at the end of steering gear shaft at the bottom of housing.
Janicholson
01-19-2017 12:43:15
Re: 350U power steering ?? in reply to Duner Wi, 01-19-2017 10:01:07
They are not very well stuck in the hole. Some leak, mine had to be replaced from leaking. To see if something pushed it out, clean the area and look in with a mirror on a stick. Jim
Duner Wi
01-19-2017 16:53:32
Re: 350U power steering ?? in reply to Janicholson, 01-19-2017 12:43:15
I have mine all apart. Noticed the plug was some what dislodged. Mine is getting new "O" rings, thrust bearings, one sector shaft, and grease seals. Thinking about a scheme to hold plug in place from below. Was wondering if it is even possible for steering gear shaft to contact the plug, does not seem possible from looking at it. I did have massive hyd oil leaks. Some came out the plug with vent near steering wheel and some ran out the shaft seals on either side. Only other thing I can think of is hyd oil pressure under the right conditions. Thank you.
Janicholson
01-19-2017 17:48:12
Re: 350U power steering ?? in reply to Duner Wi, 01-19-2017 16:53:32
New plugs are common NAPA parts and can be put in and expanded to seal. Cjean the housing, put a very thin #2 permatex bead on the lip at the bottom of the hole. insert the new core plug and use a blunt (1/2") diameter punch or rod to hammer in the dome of the new plug to flat. Jim
Duner Wi
01-19-2017 20:17:00
Re: 350U power steering ?? in reply to Janicholson, 01-19-2017 17:48:12
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
... [Read Article]
Latest Ad:
I NEED A PC160 FOR JOHN DEERE 100 DISC LET ME KNOW WHAT YOU HAVE
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
