My 484 had a slight miss at full throttle so I went ahead and changed the fuel filters. After changing filters and bleeding the filters as stated in the manual it started and ran for maybe a minute and then stopped and will not hardly start if it does its just for a second or two. This tractor always started good never had any issues. Ive cracked injector lines to see if there is air and there doesnt seem to be any. Im just lost... The book says to bleed both filters then there is a bleeder on the pump? I do not see one on the pump i cracked the line running to the pump from filter it pours out fuel. Whats going on here?!?
