Hi,
I am preparing to remove my front axle assembly and also repair the steering gearbox. This Super A has an enormous amount of free play that is clearly due to a problem in the gearbox. The front end is fine, but I want to remove it and paint it and also see if I can get the badly-rusted width adjustment freed up and moving.
Here are my questions
1) Can I support the tractor by putting bracing/cribbing under the flat surface on the front of the bell housing and blocking/chocking the back wheels?
2) Are there some useful tips for removing the front axle? Are there some warning issues I should be aware of such as things I may not wish to take apart due to difficulties reassembling or unavailable parts? Order of removal?
