Hydraulic Valves
Author |
Frank Cornell
02-19-2001 08:33:46
Can anyone advise if the hydraulic control valves from a 450D will interchange with a 350U.Seller has no pics so I can't tell by looking.Thanks,Frank.
JLE
02-19-2001 18:12:12
Re: Hydraulic Valves in reply to Frank Cornell, 02-19-2001 08:33:46
Valves will exchange, the handles will not. It sounds like the shaft is set up in the housing, which can be freed up, the loose handle is worn out at the splines, New handles were avialable a couple of years ago dont know about now. Valve # 365985R91 Lever # 366023R11
Jim
02-19-2001 10:59:16
Some of the valves will interchange if you change the front adjusment cover to get the right length adjuster for the single to double control. You can't even switch locations on the inside valve with the two outside valves on a 450. What is wrong with your old valves?
Frank Cornell
02-19-2001 11:39:55
Re: Re: Hydraulic Valves in reply to Jim, 02-19-2001 10:59:16
Front inside valve handle will not move at all.Rear valve handle works ok in one direction,just flops loosly in other direction.I have not removed them as am not yet ready to rebuild /replace.Frank.
Joe
02-19-2001 08:56:03
What is the part number on the one you are purchasing (365981R92?) I believe this will work. Are you replacing one on your 450D or adding one to it. If you are replacing one what is the part number of the replacement?
Frank Cornell
02-19-2001 09:38:16
Re: Re: Hydraulic Valves in reply to Joe, 02-19-2001 08:56:03
Joe,I have no part numbers available.I have a 350U and the valvles I would buy are from a 450D.Both tractors have three valves.That's all the info I have at present.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
... [Read Article]
Latest Ad:
I NEED A PC160 FOR JOHN DEERE 100 DISC LET ME KNOW WHAT YOU HAVE
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
