460 slow idle
thladw
11-21-2016 14:42:07
My 460 (gas) has been setting for a couple months. Started okay and warmed up, but can't get more than 1300 RPM. That won't cut it for plowing snow. Any suggestions?
Janicholson
11-21-2016 16:04:52
 Re: 460 slow idle in reply to thladw, 11-21-2016 14:42:07
Make sure the hand throttle lever is moving the governor lever through its full range. If it is, I would also check the air cleaner and intake (if it is making black smoke. If no black smoke, I would cjeck fuel delivery (carb drain into a can, should do a pint or more in a minute. (test it for a minute or more.) Governor work will need others to give advice. Jim
