Farmall & IHC Tractors Discussion Forum |
stuck axle clamp bolts
Author |
[Modern View] |
big_red_man
11-16-2016 18:27:49
I want to replace the (leaking) seals on my Farmall 460 axles. I'm trying to remove the wheels. First one, with a five foot cheater, I was able to loosen the inside two stud bolts. I can't budge the two outside ones. Ideas? Thanks, kelly
caterpillar guy
11-21-2016 01:54:41
Re: stuck axle clamp bolts in reply to big_red_man, 11-16-2016 18:27:49
You only used 5 Ft. I have used more like 7 and then might use 2 of us on that. Or went to the 1 inch air wrench.
504
11-17-2016 18:33:54
Put a rose bud tip on the torch, and they will come loose.(BTW, if you have never used a rose bud tip, you do not know the time and gas you can save.)
sde
11-17-2016 16:21:09
My understanding is that just heat will not get it to break loose. First you heat it and then you cool the bolt head with a wet rag. Although it is not the head that is tight, it is the thread and so you may need to improvise. I loosen a brake bleeder by heating it first and then cooling it. With just heat, it did not come loose. SDE
Ellis Kinney
11-17-2016 12:53:13
Clean around the bolts with a wire wheel. Heat the bolts with a torch. Let cool a little until you can melt candle wax without burning it. Melt it around the head of the bolt. Unbolt. Ellis
WESnIL
11-17-2016 03:40:12
Patience (and lots of it), your favorite penetrating oil (or combinations thereof), and heat. I have taken apart many an implement for restoration and generally start the penetrating oil applications days or even weeks before dis-assembly starts. In the final stages heat will be your best friend. Even if you only get the nuts to turn a little bit ideally then the penetrating oil has a new area on. Some people prefer to use heat first. That works too.
fbh44
11-17-2016 00:29:51
What's worked for me is CONTINUOUS torque, and PB Blaster, and then heat as I can get it applied. I mean really torqued and left torqued for day after day. Not just try it and go away.
jeffcat
11-16-2016 19:19:30
Yup, tell him how blasted much heat he will need! HOT Baby!
FastFarmall
11-16-2016 18:44:59
Put the torch to it, get it red hot!
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
1935 John Deere BN History - The History of My Tractor - by Alexander G. Knox. My grandfather, Orval A. Knox of Chandler, Arizona, affectionately known as Pa, purchased this tractor new from the John Deere/Caterpillar dealer (now Arizona Machinery) in 1935. It was his first new tractor and his first with rubber tires. He used it on his farm growing cotton, alfalfa, corn, wheat, milo, barley, and oats. My father, Norman L. Knox, recalls Pa putting a mower on the tractor during the day and then
... [Read Article]
Latest Ad:
11-2-34 tires
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
