rockyhawaii
I have a 51 Farmall Cub. It was running fine but I wanted to fix the electric start. It turned out to be a rusty connection and the starter works fine. BUT, I had a young helper that disconnected some wires without telling me and he forgot how he disconnected who from where. So, could someone tell me how the wiring goes? It is a 6 volt positive ground system, with the magneto. I'm getting positive test light on when the ground wire is connect to the negative battery terminal and the body of the engine. End result is a no spark condition. Question: Could one of you post me a diagram of where the wires hook up? Thank you. BTW, the tractor ran fine before I screwed it up so I think it will run again IF I haven't damaged the magneto or coil.
