I have had on and off again problems with the head gasket leaking on my Super C. I replaced the head gasket a few years ago and that fixed it but I noticed some of the studs head stretched and where not holding torque very well. I have tried re-torqueing a couple of times and that fixes it for a year or so but it always comes back. Went to change the oil today and noticed milky oil and the radiator was a low. The price of new studs is $15 each and I need 14. The newer versions of this engine just used bolts. I can get grade 8 bolts for a lot less than $15. Any reason I can't change over from studs to bolts? I would follow the torque specifications for the newer engines that used bolts.
Thanks, Duane
Thanks, Duane
