farmall 300 row crop frame channel bolts
dewy
10-16-2016 17:35:12
what size are the four bolts that connect frame to front bolster..are they 12 or 916.,,,,, ,.had to drill out,,,,,12 tap cut in to hole but was worried is might be cutting into old bolt...cant see anymore and was getting dark....thanks in advance....dewy
gene bender
10-17-2016 16:44:43
 Re: farmall 300 row crop frame channel bolts in reply to dewy, 10-16-2016 17:35:12
Just take another bolt out to see what size it is.
D Slater
10-17-2016 05:58:20
1/2 coarse thread is the original size for the 4 bolts attaching frame rail to front bolster, 1-3/8 long but 1-1/2 will work if the treads are clean. IH did use 9/16 bolts for attaching the PTO operating handle to planetary PTO units and a few other things.
THolmer
10-17-2016 05:28:13
I found the information on this site dated April 15th 2012. The information in the article says 300 and 350 were 9/16 NC. I don't have my 350 here to verify that though.
BarnyardEngineering
10-17-2016 04:48:24
What size wrench did you use to remove the bolts? If 15/16" then the bolts were 5/8". If you used a 3/4" wrench, then the bolts were 1/2".
9/16" is an oddball size. I have never seen one on a tractor.
You can also look it up in the CaseIH online parts books.
Link
It looks like the book calls for 5/8"-11 x 2" long bolts.
THolmer
10-16-2016 18:00:00
9/16 is the information I found out. And I believe that is what my 350 has.
dewy
10-17-2016 04:04:49
 Re: farmall 300 row crop frame channel bolts in reply to THolmer, 10-16-2016 18:00:00
where are you finding this info...there are 7 holes on side of bolster....4 for the frame,,,,,5th hole is in frame channel for implements...the other 2 holes are in front of bolster and they are 1/2 in..they never had anything in them...the 5th hole is 5/8...THOLMER are u positive they are 9/16..... ..any second opinions out there....thanks yall
dewy
10-16-2016 17:36:41
1/2 or 9/16 sorry for miss print
dewy
10-17-2016 20:17:22
 Re: farmall 300 row crop frame channel bolts in reply to dewy, 10-16-2016 17:36:41
thanks yall again...got them all in... they seem to be 1/2 in.....now i got to do the other side..... ....thanks dewy
