Company Logo Shop Now
Belly blade mount under fast hitch 140
Teamja2
10-13-2016 15:42:48
Does anyone have diagrams or pictures of how a grader blade mounts under a fast hitch 140? I have a substitute draw bar from a super a that may work once the fast hitch is removed but suspect there may be an easier way.
teamja2
10-13-2016 18:45:51
 Re: Belly blade mount under fast hitch 140 in reply to Teamja2, 10-13-2016 15:42:48
Thanks. Guess I should look for wheel weights now
WESnIL
10-16-2016 15:59:37
 Re: Belly blade mount under fast hitch 140 in reply to teamja2, 10-13-2016 18:45:51
I have wheel weights available and am in IL.
d7Fever
10-13-2016 17:50:10
Forgot to mention the mounting piece for the grader blade. It is a u-shaped piece of flat stock, about 1/2 inch thick by 3 or 4 inches. bolts to the big bolts on the bull gear housings. Then the plow mount bolts to that.
d7Fever
10-13-2016 17:44:22
Have to take off the whole lower rear fast hitch, then you can mount the grader blade. Easy to do, remove 2 rear top pins on fast hitch, then remove front pin on lower yoke , then put lower yoke in the "keeper" under the floorboard. Should take you about 10 minutes. I tried the mid mount grader blade, didn't like it, if you need down pressure it lifts the rear wheels up off the ground. I use the blade mounted in the front as a grader blade.
Have fun.
Roster
10-13-2016 16:46:39
Don't believe the mid-mount blade will work with the fast hitch..
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
Latest Ad: Green magazine back issues for sale, in good used condition, some of the covers have mild chaffing. Have years 1991, 1992, 1993, 1994, 1995, 1999, 2000, 2001, 2004 and 2006 years available. 12 issues per year. 10 dollars plus shipping per year. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
