IH 300 Utility belt question
Scott Otoupal
02-17-2001 08:10:11
Hi y'all, Thanks for the help with the points gap, now here's another one.
I need to put a new generator belt on my Internationl 300 Utility, but the pulley for it is behind the pulley for the water pump. On initial inspection it appears that you have to actually REMOVE the water pump to get the belt off.
Is this true? does anyone know an easier way?
Thanks for any help
Bob M
02-17-2001 11:06:55
 Re: IH 300 Utility belt question in reply to Scott Otoupal, 02-17-2001 08:10:11
Scott - You gotta remove the fan belt first - work it off the pulleys then over the fan blade. The generator belt is then removed the same way.
