Hi, having trouble with my 444 not starting and wondering if anyone here has any ideas.
It looks like I'm not getting any spark. Checked by taking one plug out, connecting to its wire and holding up against the block, and could not see any spark while cranking. Also got a spark tester at the auto parts store to make this more visible and still not showing that it's getting any spark.
I do have voltage at the coil (+) terminal (same as battery voltage, about 13.4V).
I haven't replaced the points or condenser because I don't have one on hand, but I did check the points gap: 0.024, spec is 0.020.
Sounds unlikely, but I did turn the engine over by hand with the dist cap off and made sure that the shaft is turning and the points are opening and closing.
Based on the above, I replaced the coil, but still no spark.I haven't been able to find the specs for the coil windings, but the old coil measured 1.1 ohms on the primary and 5500 on the secondary. The replacement coil measured 1.3 ohms on primary, 13,000 on secondary.
What the heck am I missing?
It seems like if the points are opening and closing and the coil has voltage at the (+), it should be generating spark.
Has anyone tested a coil directly by disconnecting the wire on the (-) terminal, then connecting a jumper from there to ground, then breaking the connection to ground to force the coil to generate a spark?
Thanks for any ideas.
Keith
Keith
