AnarchyAcres
New User
My International 330 has a fast hitch with very weak "up" hydraulic power. The down power is great and will lift up the entire tractor with the engine at a dead idle. But if I have a heavy implement on the hitch, I have to race the engine and wait a minute to pick it up off the ground. Once the implement is picked up, it will stay up for a long time when the tractor is parked (quite a few weeks I would say, although it will eventually lower to the ground).
So, my question is, what should I fix first? The fast hitch has a hydraulic circuit with both a check valve (365452R91) and a control valve (365981R92). Is it possible that the check valve has some weird cross leakage that weakens the up lift? Or is the control valve the problem? Like I said, the control valve works great on the down stroke, so is it possible that the control valve would have plenty of pressure in one direction, but not the other? I'm also curious to know if these valves can be rebuilt in place by just pulling the spools out and putting new o rings in. Thanks for your advice, I could use some ideas here. This tractor is very important on my small farm.
