International 300 Utility point gap or dwell
Scott Otoupal
02-16-2001 15:19:46
I have an International 300 Utility and am replacing the points, condenser, rotor, cap, wires, and plugs. Does anyone know what the point gap, or dwell should be. This is the 4 cyl gas 169. Thanks for any help
JLE
02-16-2001 15:49:03
 Re: International 300 Utility point gap or dwell in reply to Scott Otoupal, 02-16-2001 15:19:46
.18 on the points.
Scott Otoupal
02-16-2001 21:49:28
 Re: Re: International 300 Utility point gap or dwell in reply to JLE, 02-16-2001 15:49:03
Are you aure it is .18 and not .018
I get no fire at .18
dick
02-18-2001 09:03:21
 Re: Re: Re: International 300 Utility point gap or dwell in reply to Scott Otoupal, 02-16-2001 21:49:28
My operating manual for the 300U calls for the point gap to be 0.020 inch. A gap of 0.180 inch would be pretty extreme - more than likely that the points wouldn't close at all with the gap set that wide (probably why you're not getting any fire at that setting).
dick
02-18-2001 09:00:16
My operating manual for the 300U calls for the point gap to be 0.020 inch. A gap of 0.180 inch would be pretty extreme - more than likely that the points wouldn't close at all with the gap set that wide.
