Farmall cub
A friend of mine just bought a 51 farmall cub. It had been parked for three years, He put fresh gas in it and it fired up. The engine won't
accelerate when you move the throttle. Could something be stuck in the governor? Thanks in advance for any help.
Make sure the throttle plate is not sticking and the fixed main jet in the carb is not partly plugged. Also rod from carb to governor arm is not stuck.
You dont need to start engine but when you move throttle does the arm move on the gov move when you move the throtle. Can you move the rod going to the carb
