Company Logo Shop Now
help w/decal placement on A model
burrpenick
08-19-2016 12:33:57
Where does the 'OPEN >' go?
How about the 'Hitch only to drawbar or front pull hook and not to tractor'?
Finally, the O D B..........I believe it goes on the gauge and knob box right in front of the driver' specifically beside the alum KNOB, but does it attach to the LEFT of that knob in a veretical position?
George in NC...........getting close!
burrpenick
08-19-2016 13:35:44
 Re: help w/decal placement on A model in reply to burrpenick, 08-19-2016 12:33:57
Thanks, I finally found out the ODB for for the light switch- off/dim/bright. I have no shutters so the open wont be used; the dont tow sticker has both front and back worning, so I'll put it on the seat anyway. THANKS!
gene bender
08-19-2016 12:46:59
Open is for the shutters and if you dont have them dont use it. If you have a regulator you use the ODM on the left in vert position. If you still have the FOUR position control you use the four position decal still on the left vert position. You said A as it came with cut-out but mite have been changed to a regulator. Hitch only to drawbar goes on the back of the seat. The pull only from front is not original and not used. Some decal sets have decals that are not original just like gear selection as its stamped in the cast on the tranny.
Today's Featured Article - Tractors and Winter - by Staff. Unfortunately, tractors and winter don't mix well. It seems that I can start out with my tractors in great running condition but sometime during the long cold dark winter they quickly revert to the lawn-art category. The lack of running, cold weather, and admitted neglect all take their toll on a machine. If you are lucky enough to not need your tractors during the winter months you can perform a few simple maintenance items to winterize and come spring have them going by reversing the process. If you need your tractor in ready-to-run condition (like that ... [Read Article]
Latest Ad: I HAVE A FRIEND THAT NEEDS A GOOD STRAIGHT NOSE CONE FOR FARMALL C LET ME KNOW WHAT YOU HAVE [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
