Farmall & IHC Tractors Discussion Forum |
Looking for torque specs axle clamps, Farmall 400
Author |
[Modern View] |
Redturbo
08-18-2016 21:46:55
My Dad just brought a Farmall 400 last weekend, I hauled it back for him. The rims were put in dish out, putting them to dished in right now. Doesn't anybody know what IH torqued the 4 bolts that hold the hub to the axle? There 7/8 fine thread grade 5 bolts. I have searched the internet & found a wide range of torque specs for 7/8 bolts. I rather not break them off, going to be ordering service manual for this tractor from binder books. As its not a W series, so its weird to us.
thanks
Redturbo
08-24-2016 19:47:50
Re: Looking for torque specs axle clamps, Farmall 400 in reply to Redturbo, 08-18-2016 21:46:55
Great info D Slater, I backed the bolts down to 400 ft lbs. Thanks again, Scott.
Redturbo
08-20-2016 11:15:34
I searched for bolt torque specs online, get a few different numbers. For an average, 7/8 grade 5 bolts torque was 355 ft lbs, 7/8 grade 8 bolts were 500 ft lbs. I picked up 8 new grade bolts & lock washers. Put never seize on the threads on them, torqued to 450 ft lbs. I was just wondering what the cast cap that the bolts thread into would strip out or break at? Think I will just stop there. Thanks guys.
D Slater
08-21-2016 17:11:18
Re: Looking for torque specs axle clamps, Farmall 400 in reply to Redturbo, 08-20-2016 11:15:34
Maybe my manual printed in October of 62 has a mistake. It says 240 to 280 ft. #. I need to check that out. No lock washer was used on the bolts. They changed bolts around serial 9 or ten thousand. Bolts used after that were longer and were smaller between threads and to about 3/4 inch below head.
D Slater
08-23-2016 04:57:28
Re: Looking for torque specs axle clamps, Farmall 400 in reply to D Slater, 08-21-2016 17:11:18
After figuring out the first manual I looked at must have a misprint for clamp bolts on a 560. Looked at a 400 operators or final drive manual that doesn't give a torque but a 450 with 4 inch long bolts says 390 to 440 Ft. lb.
The tractor vet
08-19-2016 20:30:05
Ya want around 475 ft.lbs on clean chased threads with a bit of lube , you can use engine assembly grease or never seize
F-Dean
08-19-2016 07:33:23
Yes, switch to grade 8 bolts! Never too safe, especially when traveling in road gear.
D Slater
08-19-2016 06:57:23
240 to 280 for grade 8 clamp bolts. Don't remember seeing the number for the grade 5 ones. After snugging down evenly, a 3 or 4 foot cheater pipe and a pretty good bit of pressure is how I finish them off.
S2710
08-19-2016 19:38:28
Re: Looking for torque specs axle clamps, Farmall 400 in reply to D Slater, 08-19-2016 06:57:23
I agree with the cheater pipe. If you break one now it is better then when you are driving. I always say to tighten them as tight as you can and then give them a half a turn more. If you break one replace all of them because if one broke the rest are not far behind. Bob
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important
... [Read Article]
Latest Ad:
1967 Ford 3000
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
