Company Logo Shop Now
560
ky ac
06-27-2016 20:55:39
I bought a 560 with a bad Diesel engine. I have a d 282 in an old trencher machine in good shape. I've heard the crank will not work correctly on the tractor and will have to be swapped??? The trencher is a barber Greene ta 35. It looks like they just took an ih power unit and bolted it to the trencher. Any ideas are greatly appreciated!
pete 23
06-29-2016 17:33:04
 Re: 560 in reply to ky ac, 06-27-2016 20:55:39
Pilot bearing is in the flywheel, not the end of the crankshaft.
ky ac
06-28-2016 20:03:25
I understand that you can't just swap cranks, I've overhauled many tractor engines. The trencher itself is junk but the engine was overhauled recently . The tractor is in good shape but a bad motor beyond fixing. Yes I heard that the power units did not have the pilot bushing hole. Just curious before I year it down
BarnyardEngineering
06-28-2016 08:58:42
It's not as simple as just taking the crank from one engine and putting it in the other. Is the crank from your "bad" engine even any good? If the crank is any good you need it machined and new bearings to do it "right."
That said, do you even need to swap the crank? The only way to know is to dig into it and see. You've got both the tractor and the trencher. Unless you have a use for the trencher, you have nothing to lose by spending a few hours doing some investigative surgery.
steelfronts
06-28-2016 04:06:16
Why wouldn't the crank work unless there is no hole for a pilot bushing If thats the reason all it will require is removing the crank and machining a hole for pilot
kub6040
06-27-2016 21:43:41
Sell the tractor and the trenches and buy one that is ready to go. ??
ky ac
06-28-2016 20:05:28
 Re: 560 in reply to kub6040, 06-27-2016 21:43:41
No 560s here that are in much better shape
Today's Featured Article - Talk of the Town: Removin Broken Bolts - by Staff. Another great discussion from the Tool Talk Discussion Forum. The discussion started out with the following post: " How would I remove a bolt thats broken off in a piece of metal and I want to save the treads in the metal and then put in a new bolt. " ... [Read Article]
Latest Ad: for sale New mamifold for IH 504 tractor 100 plus shipping [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
