Steering parts for Farmall Super H
vjwheeler
06-12-2016 11:00:42
Need steering worn geer and other related parts for a Farmall Super H. Are there any other models such as a Farmall M, H, 350, that would work? :? Thanks.
David G
06-12-2016 14:29:47
 Re: Steering parts for Farmall Super H in reply to vjwheeler, 06-12-2016 11:00:42
It is hard to find used parts much better than the ones you have.
D Slater
06-12-2016 12:33:43
Look at Farmall IH parts for a SH on this site in steering. Will be new aftermarket parts tell you what tractors the parts can be used on. Bushings are mostly a dealer item, can find some bushings from other places but may need resized before or after installing. If tractor has a full circle gear on the splined shaft and it was never repositioned it can be moved on the splines to get unworn contact straight ahead and just get into a worn area at full turn.
Rick in Iowa
06-12-2016 12:17:07
Quoting Removed, click Modern View to seewhere are you?i have good steering shaft with worm gear for h im at garrison iowa
