anotherbri
Hi everyone,
I currently have the belly pump out of my '49 H and the input shaft is disconnected because I just changed all the seals and rebuilt the pump. I am considering splitting the tractor to go after the rear main seal and the clutch and the throw out bearing.
My question is this, does that input shaft have to be disconnected to replace the throw out bearing or anything else right behind the engine? I don't want to have to break those input shaft bolts loose again if I don't have to.
Also, does anyone know if there is a torque spec on those tapered input shaft bolts?
Thanks much,
Harry
Thanks much,
Harry
