planter part?
TUCKAWAY
Gene Bender this is the part I talked to you about several weeks ago on the phone. It came off my farmall 100 , now I dont remember what its for. I think it has something to do with planter drive chain but not sure. The id is 3/4 inch,threaded bolt,flat spot on side. I could not find any part no. or IH stamped. Any body recognize this part. By the way I did not paint this part. thanks for any help Tuck
Hope picture loads.
I have the planter clutch that works off the front lift,I will look tomorrow . I used my planter to plant corn it worked fine maybe this is an extra. thanks for help. tuck
Does that threaded bolt go all the way thru like a set screw? 3/4" seems to be a popular size for planter drive shafts and about all I can think of is that it is part of the main chain drive clutch. How it works is something I would have to see a diagram to figure out but generally the act of raising the planter causes parts to rotate over each other to disengage the drive. That has the look of one of those parts. Just guessing though. Now Gene can come along and tell me how far out in left field I am!
Dave yes it is like a set screw. Would this be used with left side dresser which I dont have ? thanks
Im not that much on the drive thingys that were used on the axles different types were used that i have found on tractors i have bought some fastening on either side or both as they did have attachments for different things. Sorry i cant be any more help probably an owners manual would have them listed but which attachment.
Nothing I recognize either. Maybe a picture of the other side would help. I suppose it looks like this side but with no flat spot.
(quoted from post at 21:32:18 06/03/16) Nothing I recognize either. Maybe a picture of the other side would help. I suppose it looks like this side but with no flat spot.
Better pictures all around would help us help you. Very intresting part though
