anotherbri
Hi Everyone,
I'm finally attacking the belly pump on my '49 H. Got it apart and the 2 needle bearings look like they could be replaced for the rotating shaft gear. The other gear spins freely around a semi-fixed shaft via a bronze bushing. That bushing can not be ordered anymore, so I found one at a bearing supply house, but it does not have the oil grooves cut into it. Now in the parts book, it lists 2 needle bearings could be used in place of that bushing. So I could try those or add the expense of machining 2 oil grooves into the bushing.
[b:9469362627]I was wondering if anyone has ever used 2 bearings in place of the bushing and if it worked out okay?
[/b:9469362627]
Also, I am changing the seals on the tranny side of the countershaft and the main input shaft. There is a slight play in the countershaft ball bearing, so I would like to replace it, but I am a little perplexed as to how that bearing can be removed.
[b:9469362627]Has anyone ever replaced the countershaft ball bearing?[/b:9469362627] It seems like the inner race is fitting snug around the shaft and there is no way to get behind it without pulling the tranny cover.
Thanks much,
Harry
[/b:9469362627]
Thanks much,
Harry
