I adjusted valves and my M and they seem to be somewhat loose. I can here some clatter from them. Would this be a problem? Mabe they nedd to be readjusted.
Re: Valve settings in reply to stevie_alc, 02-10-2001 08:08:59
Stevie I use .018 feeler gauge for setting the valve clearances cold. Make sure you are on compression stroke on the cylinder that you are adjusting. It sounds like your clearances might be too large.
Today's Featured Article - Welding Basics - by Curtis Von Fange. One of the most useful skills that an owner of older equipment can have is the knowledge and ability to weld. It seems like the older equipment can do a job, albeit slowly compared to newer stuff, but it tends to break more often. Many of the breakdowns are related to the implements that are being used: the disc, wagon or bushog are among them. Knowing how to fix stress cracks, reinforce weak joints by welding on steel support plates, or cutting and shaping parts and adapters out of raw stee
... [Read Article]
Latest Ad:
Looking for a useable engine head for 1929 McCormick deering 10-20
[More Ads]
