Farmall 300 Seat
Bill Braniger
05-17-2016 19:05:03
All you Farmall Guys,
I have a Farmall 300 with a standard pan seat. I really enjoy going on tractor cruises, but my lower back will no longer tolerate it.
I would like to try installing a modern seat, like a K&M on it, so my back would have some cushion from the bouncing. I really don't know if it can be done or how to go about it. Any ideas?
Thanks,
Bill
gene bender
05-18-2016 13:22:35
 Re: Farmall 300 Seat in reply to Bill Braniger, 05-17-2016 19:05:03
Make a base and get the real firm foam 6in or so thick it works great but you got to use the good firm stuff an upholstory shop would be a good place to go. See more and more of that type on rides. Love the one on my B with back rest.
BarnyardEngineering
05-18-2016 10:31:23
Seems pretty simple to me. The old seat suspension is held on to the battery box by four bolts. Remove that and you have a nice flat platform to install pretty much any seat your heart desires.
The only limitation is the amount of suspension you can have under the seat.
A full air ride setup would probably be too high setting on top of the battery box, which means you would need to remove the battery box and relocate the battery.
A mechanical suspension for an IH tractor might be a little high by an inch or two.
old weldor
05-17-2016 19:58:51
I have a 300 with a pan seat with a backrest, I think it was the seat that came on the 460 and 560 farmall. To me it seems comfortable.
Bill Braniger
05-19-2016 19:11:09
 Re: Farmall 300 Seat in reply to old weldor, 05-17-2016 19:58:51
Old Weldor,
How does it mount?
Could you just unbolt the old seat pan and bolt the new one on?
FastFarmall
05-17-2016 19:27:51
Well that K @ M seat is made or distributed
Well it sure should be available, K @ M, products are made or distributed there out of western Minnesota,they make tool boxes, etc, But if i was you i would get a clot seat, their will be less sweating rather then plastic.
khouse6
05-17-2016 19:27:31
neighbor put a seat from a road tractor on farmall M. it has air ride, etc.,
d beatty
05-18-2016 09:33:23
 Re: Farmall 300 Seat in reply to khouse6, 05-17-2016 19:27:31
It would be hard to put an air ride set on a 300 because it has a battery under seat.
FastFarmall
05-17-2016 19:32:37
Curious where does he get his air pressure from to operate the seat ?
khouse6
05-17-2016 19:47:12
 Re: Farmall 300 Seat in reply to FastFarmall, 05-17-2016 19:32:37
he airs it up from air compressor at his shop
