Company Logo Shop Now
560 PTO ajusting tool
hayfarmer
05-10-2016 18:18:11
I asked for some direction on building a tool to adjust the 560 PTO with external adjustment. I have seen it in the service manual but needed some direction. I was surprised with all the knowledge here that no one offered a suggestion. I have since removed the box and figured out how to build a tool that will work to push the lock away from the adjuster. I am willing to share my tool configuration with others who may have a question.
kevinj54
05-11-2016 16:33:36
 Re: 560 PTO ajusting tool in reply to hayfarmer, 05-10-2016 18:18:11
I have the books and have looked at the drawings.
Some day when I have to adjust I will make up a tool
kevinj54
05-11-2016 03:11:08
I would be interested in that even tho mine is still working good.
hayfarmer
05-11-2016 07:51:26
 Re: 560 PTO ajusting tool in reply to kevinj54, 05-11-2016 03:11:08
The tool shown in the tech manual is a piece of metal with several bends. I had and old medium sized screw driver with about an 8 inch shank. I bent it approximately 1 1/2 inches from the outer end about 60 degrees. I was going to put more bends in it like the tool has but found with the pto brake in position per the book, put screw driver in adjustment hole, bent tip down, it will push against the lock button to release it. If you have the service book this will be more clear.
Today's Featured Article - Tractors and Winter - by Staff. Unfortunately, tractors and winter don't mix well. It seems that I can start out with my tractors in great running condition but sometime during the long cold dark winter they quickly revert to the lawn-art category. The lack of running, cold weather, and admitted neglect all take their toll on a machine. If you are lucky enough to not need your tractors during the winter months you can perform a few simple maintenance items to winterize and come spring have them going by reversing the process. If you need your tractor in ready-to-run condition (like that ... [Read Article]
Latest Ad: I HAVE A FRIEND THAT NEEDS A GOOD STRAIGHT NOSE CONE FOR FARMALL C LET ME KNOW WHAT YOU HAVE [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
