Farmall M thermostat
txdutchman
04-26-2016 16:03:07
third party image
third party image
Ordered new thermostat for our M. They tell us this is supposed to work? It just sits in the housing loose, nothing to hold it. It is quite a bit smaller then the original. I keep telling them it's the wrong one, they say it will work. I sure don't know how. Someone educate me please? Thermostat came from YT parts. Incidentally, when you look up the thermostat for an M, it shows a picture of the original one. Not the too small new one.
txdutchman
05-01-2016 17:52:59
 Re: Farmall M thermostat in reply to txdutchman, 04-26-2016 16:03:07
Thanks guys. Thermostat is on it's way back. Got the right one coming.
Andrew had also ordered a set of main bearings. Came in Thursday. One of the halves was scratched up. Got a new one of them coming too.
Dennis K (WA)
04-27-2016 08:56:35
In January I ordered thermostat from YT for my SMTA, should be the same for your M and it was the right one, tall one. p/n R1852. $34.14
Dennis
John M
04-27-2016 02:47:19
Biggest problem would be is if they charged you for the original style tstat, like the one they show. That one there is what, 8 or 9 bucks at most any parts house.
OldFarmall450
04-26-2016 16:25:55
[quote="CVPost-txdutchman"](quoted from post at 16:03:07 04/26/16) Ordered new thermostat for our M. They tell us this is supposed to work?
[img]http://photos.imageevent.com/texasdutchman/farmallproject/websize/IMG_2987.JPG[/img]
[img]http://photos.imageevent.com/texasdutchman/farmallproject/websize/IMG_2986.JPG[/img][/quote]
Hey Dutch, not to knock the sponsor here but Steiner has a thermostat for the M that's 2.6" long and flange 2.510" dial.
My Farmall 450 came from near Abilene...close to you?
Good luck
wayne in mn
04-26-2016 17:58:40
 Re: Farmall M thermostat in reply to OldFarmall450, 04-26-2016 16:25:55
Get an original thermostat; the automotive style just does not do the job!!
txdutchman
04-26-2016 16:53:29
Ok Thanks. Previous parts ordered for it came from them, YT is a little cheaper. Guess you get what you pay for. I'm about 3 hrs west of Abilene.
OldFarmall450
04-26-2016 16:22:35
Good luck
pete 23
04-26-2016 16:19:43
Don't use that new thermostat. The one you need is available at IH and has a long tube like old one. That is for a reason to provide a internal bypass system until thermostat opens. IH had a mistake in their parts books many years ago and supplied a thermostat like that new one you have there but quickly recalled them for that application. That being said, your housing is probably rusted and eroded enough that even with the correct thermostat your engine will not warm up without a load due to coolant being able to go on around the tube and to radiator. Others will argue of course but a garden hose stuck in the assembled housing will prove to you weather or not the thermostat is blocking flow, except for a small amount, as it should until it starts to open.
txdutchman
04-26-2016 16:57:01
 Re: Farmall M thermostat in reply to pete 23, 04-26-2016 16:19:43
Ok, we'll send this one back! Yes, it's a bit rusty! Thanks for the heads up!
Janicholson
04-26-2016 17:47:02
 Re: Farmall M thermostat in reply to txdutchman, 04-26-2016 16:57:01
I recommend putting a stainless steel ""gasket"" (made to match a housing gasket except for the bypass hole) and drilling a 5/16 hole in the stainless at the bypass opening. @ gaskets and the new restrictor, and it will warm up. Jim
