The fuel pump on my O14 pushes fuel but not enough to keep the engine going.didn't find any holes in the diaphragm. Any hints on where to look for problem? Thanks in advance Chuck K.
Re: O14 weak fuel pump in reply to chuck kaufman, 04-24-2016 14:27:08
Chuck,Ive extended the pump rod by building it up with weld than Ive used sever gaskets behind the pump as shims and adjusted the shims incase the pump pumps to much
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
